Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Tue Jun 14, 2016 6:02 pm
Although the light is off, doesn't mean it's not storing a code. Some events won't trigger the SES light until a 3rd trip, some will trigger it on first event. Depends on the code. May want to put a scanner to it anyway to see if there are any clues.
When in gear, does it idle back down? May also want to check the linkages, throttle body. The FSM also has a diagnostic procedure for checking idle speed, timing, and idle air mixture ratio. May want to start there.
