Marc22692 »
https://forums.nicoclub.com/marc22692-u225764.html
Sun Sep 29, 2013 9:12 am
Hi everyone my name is Marc. I have a 1998 QX4 that has 192k on it and runs like a champ. My wife drives it most if the time and when she went to work the other day she noticed that when she turned on defroster, as it was the first semi cold morning this year, that the heat would not engage. Meaning, it was blowing full blast set to 85 Degrees but even after 20 miles it seemed to be blowing really cold air. So I thought maybe it was thermostat because upper coolant hose was hot but lower wasn't at all. Also the heater coil hoses were cold after warm up with heater engaged. So I replaced thermostat. That was a waste of time as after I was all done I tested it in hot water and the thermostat worked fine. So the million dollar question is.... Is there a heater control valve, if so where is it located, do it use vacuum or electric if there is even one, can I hold it open manually, and finally am I even on the right track? Thanks ahead of time fir any responses!
Marc
