fueler »
https://forums.nicoclub.com/fueler-u54519.html
Thu Feb 01, 2007 8:45 am
This is a somewhat common problem on R50's built from 96-98
Your rear bushings on the traction bars are probably shot. Check the lower link on the rear suspension by twisting it. If it twists very easily, you need new bushings. You can either buy just new bushings and have a shop press them in, or you can just buy new lower links. (The links are the metal bars attached to the axle and to a large bolt on the frame about 1 foot in front of the rear tire. The parking brake cables run along them.) The lower control links (#9) are 2 of the links that locate the rear axle. There are 5 links: two lower links (attached to the frame immediately in front of the wheel well) and two upper links (#7), and the panhard rod (#4).
The stabilizer links that you supposedly can get from AC are short vertical rods that connect the rear antisway bar to the frame (#13).
