bullittandy »
https://forums.nicoclub.com/bullittandy-u30909.html
Tue Jul 10, 2007 3:23 pm
I recently replaced the gaskets on my 97. The passenger was easy but tedious and the driver was about the same.
Note: If you don't want to be ridiculed by some members of this site then ignore the following:
The driver's valve cover is difficult to remove without removing the brackets that support the air intake. However, the middle bracket on the air intake is extremely time consuming to remove (hidden bolts, bad placement) so I cut mine off with a dremel tool.
There are pcitures here somewhere so do a search and you'll see what I mean, or maybe some fine Nico soul will post my write up.
