1998 Q45 P1110 code!
reidness
Car: 1998 Q45
Just picked this ride up a couple of weeks ago, 104.000 and in great shape, anyway last week it started to hesitate and stumble at slow acceleration but not to bad and i just thought it might be a filter? anyway it just tossed out this P1110 code about the valve timing control left bank, so i started with a fresh oil change with 10w30 syn, after that the car was even worse than before with the acceleration and a little bucking? i tested the connector for the proper voltage it was good, i pulled out the selenoid and it looked good, i jumped a couple of wires off the battery and the selenoid pulled in and seemed to be fine? so im not sure if its the sensor or what! and will this cause the performance problems? or am i also loosing my fuel pump? i have no humming from it but its the right age. help would be very welcome thanx reid
reidness
Car: 1998 Q45
also wanted to tell you that in aug of this year th e PO had the cars 100k service with a fuel line flush and oil change and filters{ not sure about the fuel filter} the work was done at a firestone and i have the paperwork, in the notes it said it was taken in because it was having a hard time starting! fuel pump? let me know what you guys think, im a poor s.o.b by the way.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Customary for unknowing owners to replace all fluids and filters for a baseline. Good idea for a senior Infiniti technician to inspect the car after purchase to highlight unknown defects ignored by not performing initial pre-purchase inspection.
$50K imported luxury sedan is not a good choice for someone not financially equipped to restore and maintain it. Parts prices and labor prices will only increase.
Did non-Infiniti specialist cahnge the oil filter from the top? The fuel filter is trivial to change.
