This may be the case with the first generation Q. I own a 99 Q and I have always removed the oil filter from the top. The MAF is not even in the way.911/Q45 wrote:You're asking for trouble removing the filter from the top. Large # of MAF sensor problems are due to flexing or disconnecting/reconnecting that item.
It was the only way i could see to get it out. I might have to take you up on that offer on the plugs. From what i can see, i'm guessing i'll have to remove the plenum and go from there?VA99Q45 wrote:
Dodgeyaussie, if you have problem changing the plugs, I can guide you through it.
Exactly right! The manual states to remove it from underneath.911/Q45 wrote:You're asking for trouble removing the filter from the top. Large # of MAF sensor problems are due to flexing or disconnecting/reconnecting that item.
