tfvesquire »
https://forums.nicoclub.com/tfvesquire-u83121.html
Fri Jun 28, 2013 8:07 am
Update:
Since I tried to clean the IAC without removing it since I did not have a replacement gasket on hand, I decided to unscrew the IAC motor/plunger and clean that as well as spray a liberal amount of Deep Creep inside the opening that houses the plunger. On a 1/2 tank I poured in some Lubro Moly injector cleaner. Then, I used some Q-tips and a small rag to clean out the inside chamber and vent hole of carbon. Then I sprayed another healthy dose of DC into the TB. Let it soak for about 15 mins and started it up and gas it some healthy gas to blow it out. Drove the car around the block since it was late and let it idle a few mins. Seemed to idle smooth, but I had my fingers crossed for the next morning's test drive.
Started it up this morning and there was no apparent idle fluctuation. Let it run about 3 mins and proceeded to drive to the car wash. No hesitation in the 2 mile trip, ran it thru and was on my way driving in to work. On the way I had a chance to open it up several times with some good WOT bursts. Did not see anything from the tailpipe in my rearview mirror, but after about 15 mins of driving, I started to get some hesitation and idle swings again and it even stalled once. After much swearing and cussing, I gave it another series of WOT bursts and it ran better, but then hiccupped again two more times. By the time I got close to downtwon Chicago, it seemed to be running smoother and idling fine. Light acceleration had no issues and seemed to have more even power band without the need to floor it to "clear its throat". I guess I will know whether I cleaned everything out or if the idle issue will again rear its annoying head on the drive home.
The only sensor I haven't addressed is the EGR temp sensor located at teh base of the EGR valve. Does anyone know whether that sensor (assuming it is caked with carbon) could be contributing to my issues? The car will definitely run rich versus lean when the idle starts to go ape sh*t sometimes to the point of stalling.
Will update again after I put some more highway miles on the car this weekend.
