1998 Q45 engine
fgjr57
Car: 1998 Infiniti Q45
I bought a used motor for my car that I was told it was a good motor but when we removed the valve cover I found two rocker arms that must have fell off. What would cause this?
Q451990
:welcome: to NICO!
This is not a common issue. I hope you can get your money back...
I'm going to guess that there was either a ton of spark knock causing the bolts to come loose, or someone started to dig into the engine to diagnose a problem, found something they didn't want to deal with, and closed it back up?
Heath
fgjr57
I didnt see any wrench marks on bolts and they where tight
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
There is no way that happened from "natural causes" as these motors are very well built. You have been scammed, as Heath said hope you can get your money back as someone has flat ripped you off.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Agreed.. Internally the VH series engines are very solid, easily seeing 250k miles before they need to be torn apart if they're well taken care of..
