I just found this, similar to what i was saying..."If your ignition coil is hot and you can get a spark coming off of the coil wire, the only thing I can suspect would be a problem with a bad rotor in the distributor. If the coil is delivering to the distributor but it travels no further, the energy must be dissipating somewhere. If a rotor has a short, the plug wires will never be delivered any spark.
Also a distributor cap with a missing carbon button which rides on the top of the rotor may be missing. I really cant think af any other things it could be.
I just read another post and the guy was saying that the distributor bearings are know to fail, and to test this pull the distributor and turn it by hand to see if it's hard or rough to turn, if that's the case replace the distributor.
I'll keep looking around for you, beings i'm bored! i'll keep "editing this spot.
This may sound silly but did you check all your fuses?
Check the MAF sensor. If it's dirty, you won't be able to start the engine...i doubt it's that.
I read a couple stories about the same as yours but, nobody ever came back and said what they did to fix the problem. Let us know...and good luck.
