Thanks,Towncivilian wrote:A clogged fuel filter could be a potential cause. Before attempting to start, cycle the key from off -> on several times to build up fuel pressure and see if that helps it start. If so, the fuel filter is a likely culprit. Replace with a NAPA Gold 3023 or Wix 33023. Replacement guide is here.
Check under the distributor cap for dirt or dust build up, and blow it out with some compressed air if there is significant build up.
The check engine light did not come on.fueler wrote:did it throw any engine lights? if so, the ECU will tell you what has failed.
That is good news I suppose since I doubt I can change the filter out where the car is now. I am probably the wolds worst mechanic, how do I check for spark?Chuck Tribolet wrote:I don't think it's the fuel filter. Failing fuel filters fail at full throttle first.
Test to see if you have a spark.
One more question...Chuck Tribolet wrote:I don't think it's the fuel filter. Failing fuel filters fail at full throttle first.
Thanks,Towncivilian wrote:I believe you spray starting fluid into the intake somehow. Removing the air filter is probably the simplest method to do so.
Ok, the problem was the round plastic base of the rotor had shattered so I now have a new rotor and distributor cap and the car runs great but I do hear a clicking noise from insinde the cap. Is this normal?Deadpath wrote:Thanks,Towncivilian wrote:I believe you spray starting fluid into the intake somehow. Removing the air filter is probably the simplest method to do so.
I will go to work on the car in an hour. Right now I am thinking it might be a dirty distributor cap but will take my PC along and post what I find.
Thanks all for the help so far.
Ok, I was able to check for spark today before opening the top and realizing the problem. There was no spark of course because the rotor had fallen apart.Chuck Tribolet wrote:I'd look very carefully for a piece of the broken rotor still inside.
To test for spark, pull a spark plug, put the wire back on the plug, and set the plug so it touches a grounded metal part of
the engine that's away from the empty spark plug hole (fuel mixture comes out that hole while cranking, and the spark
could light it). Have a buddy crank the engine over while you watch and listen for the spark.
The car is now barely running. Today as I was driving it was missing at high speed then became worse to the point that it was barely able to do 30 MPH and RPM's were jumping up and down. I am thinking that the distributor itself is bad causing the rotor to not spin properly and really screwing the timing up.Chuck Tribolet wrote:The rotor should not be touching the contacts in the cap. There should be a very small amount of clearance (it's probably
speced in the FSM) and the spark leaps the gap.
I realize most people must be busy with holiday fun but if anyone can tell me where the LED is I would really appreciate it. I want to make sure it is clean before I go and buy a new Distributor.Deadpath wrote:One other thing:
Where is the LED in the distributor? I am not seeing one.
