There are so many parts under the car that use rubber it would be difficult to say where they come from. You will likely have to get under it with a light and try to see if one of the rubber bushing is breaking apart. Next time before you drive it look for the rubber balls under it then use a light to look up into the car above that area to see what it dropping it.
