This forum has been a great help to me in the past. I hope that this will help someone else out.
The back ground is that I've recently caught up on maintenance on a family owned '98. Started with a new distributor to fix a failed camshaft sensor. Followed up by timing belt change, drive belts, and plugs and ignition wires, and the upper plenum off to replace a collapsed lifter. The new distributor then failed, this time no spark, so now on the third distributor. it ran very well for a few days and then had a flashing Service engine soon light and the P0300 code. Multiple misfires!
I checked the usual suspects. No air leaks or split hoses around the plenum. Fuel pressure good when running. Checked fuel delivery volume and to make sure there was no contamination. As it was the multiple misfire code, I was convinced that it was another distributor problem, even though the sparks looked good, and the the cam sensor had good 120 and 1 degree signals. i bought and fitted a third distributor, this time from Cardone, in the hope that it would be more reliable. No change, still engine shaking at idle, and throwing the P0300 code. Once in a while a flashing SES light
I was now only running the engine while parked, and not driving it. There was an obvious misfire as soon as it was started. Cold starts were good, but sometimes it was slow to fire when it was warm, and the rpm was slow to pick up. Sometime the engine seemed to clear and run smoothly above about 2500 rpm. Once in a while it would pop in the exhaust, as the rpm wound down after revving it. Then it gave a P0306 code. I pulled the No 6 plug and it was dry and sooty black. I cleaned it off and swapped it into the No 1 cylinder. It was a new NGK, and I didn't really think it was faulty, but didn't want to have to change it out of No 6 again if it was.
Slow to start after the plug change, and missing almost at once. More throttle blips and some longer revving periods and back to the P0300 code. Clear that and try again. This time a P0302 code. Pull that plug and it looks perfect, just like new.
Now I'm really confused. P0300 is misfire on two or more cylinders. The 02 and 06 codes are for specific cylinders. I'm still thinking it must be some general fuel, ignition or air leak. But still can't find anything.
I started thinking about injectors, found a nice Youtube (
https://www.youtube.com/watch?v=IYsfBWC4ilo) on how to check the injector ohms by accessing the two plugs on the passenger side valve covers. They all Ohmed out at 14.5 or so, and all clicked when I powered them with a 9v battery.
I'm struggling to think how a faulty injector on one cylinder can give a multiple misfire, but thinking about the sooty No 6 plug and the super clean No2, maybe No 6 has a leaking injector and the ECU was leaning off that bank and giving lean misfires and the multiple code.
I really didn't want it to be an injector, but I bit the bullet and lifted the plenum again. Second time around was easier. I just cut the vertical coolant hose at the back, and replaced it with a length of 1/2" coolant hose, 4 and 3/4 inches long. The 90 degrees hose was still pliable and flexible, so reused that. With a bit of lube they both went back on easily.
Back to the injector story. I bought three remans from the local Napa, for speed, price, and convenience, as I wanted to do the whole bank as I was in there. One was DOA, another had a sort of ringing tone when powered, and Ohmed at the bottom of the range, but the third one Ohmed mid range and had a nice click, so I fitted it in No 6.
It took twisting and a lot of pressure to get the new injector to seat, and I had to use the injector retainer, and the securing screws, to get it fully home. I jumped the fuel pump relay to pressurize the system, and there were no external fuel leaks at least.
Buttoned it back up, and it fired up pretty well first revolution, and ran smoothly, just like it used to.
So, a single leaky injector can give multiple misfires, as well as the cylinder specific code for the leaky one, and a cylinder specific code on the same bank.
If I'd gone more old school, and thought more about the state of the spark plugs, then maybe I would have got there sooner, and not wasted time and money on the distributor. With hindsight the clues were all there, I just let the codes confuse me. Oh, and check your injectors before you fit them.
Hope this helps someone.
