johnny98pathy »
https://forums.nicoclub.com/johnny98pathy-u139381.html
Mon Jul 27, 2009 7:10 pm
Hello,
I just bought a 1998 Nissan Pathfinder SE w/130,000 recently and have put a lot of money into it. (Timing Belt, Exhaust, Water Belt, Passanger side exhaust manifold, front axels) It's been running like a dream until the other day when I was driving on the freeway using cruise control after an 800 Mile trip and I noticed the car start stuttering and hesitating to maintain a constant speed.
Once I got into town things got a lot worse. Stepping on the throttle as I normally would results in serious lag, stuttering (jumpy rpms) and hesitation. If I drive the car extremely slowly and keep the rpms under 2000, the problem will not happen. It will die in traffic simply idleing. However, when it's idling, it sounds normal.
I took it to my mechanic who hooked it up to his diagnostic machine and it reported random misfire. However, no check engine light is on. My mechanic suggested a tune up. I personally replaced the rotor, cap, plugs, and wires. (With the exception on plug #6 which is seemingly impossible to get at) I'll have my mechanic work on that tomorrow.
Although possible, I feel it's highly unlikley that the problem is the one unchanged plug and wire (#6). After some research, I suspect that the issue could be one of the cylinder coils. However, I have no idea. I've got to get this figured out... as this SUV is my only means of transportation.
Thank you in advance for any help you can offer! Johnny
Modified by johnny98pathy at 10:20 PM 7/27/2009
