Alibireason »
https://forums.nicoclub.com/alibireason-u299870.html
Mon Apr 14, 2025 3:22 pm
My 1998 Pathfinder is giving me DTC P0161 for a downstream O2 sensor. Around 2020 I replaced both upstream sensors (no code-just maintenance) but did not replace the downstream sensors because it seemed difficult to snake the cables from the CATS up through to the top of the engine. Now I have a code for downstream O2 sensor and would like to replace them both but I have some questions.
What is the best way to replace these sensors? It looks I will need to send them up through the engine to plug them in from the CATS. My only thought on how to do this is to unhook the sensor from the CAT, install the new sensor into the CAT, tie together the new and old sensors and somehow pull the plug up through the engine and finish plugging the new one in.
Am I overthinking/missing something? Any tips are appreciated.
Also looking at Rockauto for the parts I found the two Downstream sensors (13257 downstream left) and 13264 (downstream right). One of them mentions it is for an auto transmission, the other does not mention it. Can I assume they are both for automatic?
Thank you!
