ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Sat Oct 01, 2011 9:29 am
Get out your manual and trace the wires from that load side of the fuse. At 10 A it is most likely a control issue.
Charge the battery to full, then you need to load test the output and see what amount of current draw and then isolate each part of the fused system to find the draw, it may be related to the 10 A fuse that blows.
You must be definite and thorough and record everything, until you find the culprit circuit. Then with the circuit now known look in the book as to what is on this bad circuit and start again now with this circuit and eliminate each load in the circuit until you get no load reading. Then replace the blown fuse, with the same exact fuse, if no blow you have it.
Now check the device that caused the problem and see if it is really needed, if so replace it.
Now in the final step, with everything replaced see if you have a load on the battery that should not be there, test, verify, secure.
A fuse that blows immediately is usually a short circuit as compared to an over load. A short could be faulty wires, grounded line feed or burned load going to ground.
An overload can be a burning component not yet fully at 0 ohms but more use will get it to a short.
