Hi Everyone.
At the recent days I'm having some issues about lack of power. Engine starts great, runs smooth and perfect, when you sit on throttle revs and accelerates brutal.
But....
While cruising at between 1500-2000 rpm (where you drive it most) when you increase the throttle, especially uphill, it hesitates to rev up, it actually revs up but without shuddering a giant powerful hand gently tries to pull the car back and releases... That's what you feel. No shudder, no feel like misfire, if you sit as a passenger in the car you may won't feel it If I don't tell you it's that light but kills the fun, no more enjoying the ride...
What I did;
-brand new distributor
-new spark plugs
-new plug cables (OEM, Yazaki)
-new water pump and belts
-new radiator
-new whole exhaust system
-changed every fluid of the drivetrain (front-rear diff, ATF main and the secondary transmission)
-and so many other minor parts like thermostat etc...
But I didn't change any sensors like MAF, Oxygen sensor which are suspicious to me, also the fuel pump. But it runs good in my opinion so I can ignore the fuel pump maybe, well I don't know and it makes me crazy. Here how it moves, which is OK to me.
https://www.youtube.com/watch?v=U1CqzEbeiAk
Car is not displaying any codes.
Any ideas you have?
Thanks.
