A leaking fuel pressure regulator could cause all the symptoms you have described. A fuel sending unit, which is part of the fuel pump assembly inside the fuel tank, is the device that sends a signal to your instrument cluster fuel gauge to tell you how much fuel is in the tank. Scratching my head over how that was thought to be an issue unless the internal fuel lines in the tank were leaking back into the tank.Trooper329 wrote: ↑Sat Mar 25, 2023 9:15 am... They told me my fuel sending unit was bad (fuel leak) ...
Thanks for taking the time to respond! The dealership had stated there was a fuel leak of some kind. It was likely leaking into the fuel tank, as you had explained.mdmellott wrote: ↑Sat Mar 25, 2023 9:52 amA leaking fuel pressure regulator could cause all the symptoms you have described. A fuel sending unit, which is part of the fuel pump assembly inside the fuel tank, is the device that sends a signal to your instrument cluster fuel gauge to tell you how much fuel is in the tank. Scratching my head over how that was thought to be an issue unless the internal fuel lines in the tank were leaking back into the tank.Trooper329 wrote: ↑Sat Mar 25, 2023 9:15 am... They told me my fuel sending unit was bad (fuel leak) ...![]()
Thank you for responding! While the injectors were from various brands, they all tested fine and the dealership had checked them. I’ll make sure that when I take it to the mechanic, I’m able to see the data you informed me of! Thanks again!MisterH wrote: ↑Sat Mar 25, 2023 10:00 amWow, you've certainly done a lot of work to sort out the problem so it must be frustrating to still have that issue. The first place I'd start would be testing live data with an appropriate scan tool. I'd bring the engine to operating temperature and look at the short-term fuel trims for each cylinder bank. Would have been nice if you could have gotten the STFT data from the dealer you took it to. Since you wrote that you had a stored P0301 and 304 codes I'd also look at those spark plugs to see the burn condition. White smoke out the tailpipe initially could mean excess fuel being dumped caused by a faulty injector. One concerning issue could be the fact that you used "multiple brands of new injectors." The best injectors for this engine - Hitachi FIJ0006 - are no longer manufactured and unfortunately have been replaced by a bunch of cheap chinese knock-offs typically sold on ebay and amazon -and are poorly calibrated junk. You must have injectors that are flow-matched for each bank or you'll have problems. The flow rates are indicated by a colored dot at the neck of each injector - usually black or blue for your vehicle.
I went through the hassle of doing all my injectors last year and had to settle on reman injectors from GB engineering. Big mistake. Two out of six were initially defective and last week the #4 injector started sticking open and I now I have to pull off the manifold once again. You could have multiple issues at work here, but live data will tell you a lot in terms of identifying the root cause.
You also paid the dealership to fix the issue you are having but they failed to do so. You can check a fuel pressure regulator a couple of ways to verify it does not leak. A pressure gauge test to validate your fuel pump pressure and pressure regulator at the same time is the best option. A borrowed test gauge kit is often available at auto parts stores, like AutoZone and O'Rielly, at no cost. Another possible check on the regulator is to pull the regulator vacuum hose off the intake plenum. Do this when the engine is warm. Not immediately after you turn off the engine but after 5 minutes or so. If there is a regulator leak, the fuel pressure will leak into that vacuum hose and you will see a small amount of fuel drip out of the hose when you pull it off the intake plenum. This is not as assured of a test as using a test gauge, but if the leak is bad enough, there will be fuel dripping from the hose.Trooper329 wrote: ↑Sat Mar 25, 2023 9:32 pmAdditionally, I replaced the fuel pressure regulator in 2018(?). Lol. The dealership did check all aspects of the fuel system, as far as I’m aware. So I think that’s likely not the issue.
MisterH wrote: ↑Tue Jul 11, 2023 11:29 amThose trims do confirm you're running really rich; particularly on bank 2 (cylinders 2,4,6) VSTar's explanation of fuel trims was outstanding of course but I know this means you still have to figure out why, as he indicated a vacuum leak will cause a lean condition; not rich. When you're running that rich it will show up on your spark plugs. The ones most affected will be very black, sooty and even somewhat glossy. You could pull each of your plugs and have a look at them to determine which are most affected. Since your STFT on bank 2 is the worst you could start there (even though I know #6 is a PITA). One of the top reasons for running rich is a leaking or faulty injector. You mentioned at the beginning that you replaced all the injectors, but with different brands. That alone shouldn't be a problem but I refer back to what I wrote earlier:
If you have even a single injector with a different flow rate - or one that is leaking - it will cause a rich condition and will probably set a fault code for the affected cylinder(s). However, the engine management system for the VG33e only compensates for fuel delivery on bank 1 or 2 - not by individual cylinders.
Maybe I’m just tired, but mind explaining LEO?
macgiver wrote: ↑Wed Aug 02, 2023 6:01 pmSo sorry , Law Enforcement Officer is what you'll hear as shortened A C R O N YM , scuse me , it was a juvenile......... no INFANTILE on my part of the " trooper / pooper " joke , my bad .
6 2 and even over & out ! ...........( d*** Tracy ? )
Honestly......................................................................so sorry![]()
