Not sure if idler pulley, AC, Power Steer, Alternator, Crank pully etc
Mechanic gave free advice and said the AC was the noisemaker but
I need to double check as the noise level has increased
Will slightly sandpaper pulleys in case of being glazed
Plan to get shorter spare belts to remove the alternator and AC temporarily from the circuit
to see if they are the noise makers
May also remove the idler pulley from circuit too or-not sure
Maybe try to oil the pulleys while they are moving to see if noise reduces
Will check to see if pulleys are on tight (including the crank)
Have never done this
Any good advise please chime in!!
Thanks
