Issue: Windshield wipers work fine on their own if I turn them on specifically. However if I attempt to activate the washer pump to spray the windshield, I get nothing. No fluid, no reassuring hum that the pump itself is good, and the wipers don't move. If the wipers are already turned on they continue to operate, but again no washer fluid flows. Yes, the reservoir is completely full.
I've tried to find a fuse to check, but I can't find one under the dash or under the hood the correlates to the washer pump specifically. Does anyone know which fuse I should check to ensure that's not the issue? I guess the next step after the fuse is to get my multimeter out and see if current is making it to the pump when the control is activated on the column? Other ideas?
Thanks. Alan
