Rucca »
https://forums.nicoclub.com/rucca-u71259.html
Fri Apr 18, 2008 12:57 pm
Water pump? Basically if you have no leaks, and new rad, new thermostat (installed properly, don't remember if it's possible to put that backwards on the 240), and fan working (with shroud on I assume) you either have lots of air in system, no flow (waterpump or clogged coolant passage), or.... maybe you used pure coolant?
Too lazy to post pic of bleeder valve. But there is a screw that doesn't hold anything in right on the housing the upper rad hose connects to, that is the bleeder valve. It's on the intake manifold and I think it has a gold sticker or something on it cautioning you not to open it (if it hasn't fallen off yet).
Instead of parking on a hill, just jack up the front end of the car like 2 feet. As long as the level of water in the funnel in the rad cap is higher than the highest spot coolant flows through the engine, the air should, in theory, exit through the rad cap. Rev it a lot while bleeding and just let it run with the funnel in it for a long time (30 minutes is pretty safe to say it's welllllll bled), also make sure heater is on full hot full blast to get air out of the heater core.
