sgilbreth20 wrote:hey everyone thank you for the tips.
The starter is turning over but jsut not starting. If the battery is dead would it be turning over? Yes the check engine light is on and it is on for the knock sensor. It just happened it has never done this before. We actually changed the started about 6 months ago so I know it could not be that it was brand new. My husband checked the fuses and said everything was great. I will tell him about the spark plugs tough. I cannot even get my car out of my parking place LoL
A weak battery can still turn the engine but cannot have enough speed for combustion. Check the battery connections are clean and tight and that the battery voltage is 12.5VDC with engine off. If <12.5VDC, jump start the car and it it starts, then you have a weak battery.
If the car still won't start when jump-started, then you may have problem with fuel delivery (pump. filter, leak-down), ignition, an engine sensor (e.g. crankshaft) or poor ground connections, especially on the main engine harness..
