1998 Maxima - Power Antenna Mast replacement
deyab
Car: 1998 Maxima GLE, 2009 G37x Sedan
There's plenty of posts in this topic, and I got good information to be able to do this successfully. I did notice that a lot of people seem to have difficulty with extracting the old antenna from the housing containing the motor - some simply give up (according to those posts). This was the case with me as well, but I was able to successfully extract the mast to put in a new one. Thought I would post a few pictures:
Entire assembly outside, on the floor, with two pieces sticking out:
Problem is, it just won't come out. Took a good 10 minutes of wiggling with a needle nose pliers (which kept slipping) to half destroy it and finally take it out. I took the entire thing out of the car so I can get a good grip on the sucker and apply as much force I wanted without causing damage to the car or paint. Oh, I also used a dremmel tool to cut up the top of the tube a bit to get good grip with my cheap pliers
Success:
Motor housing ready to go back in:
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
It's always nice when someone shares things like this. I had a little trouble replacing my antenna mast on my Q45 and I finally got it done and now it doesn't go all the way down unless I turn the stereo on and off repeatedly which ends up retracting the antenna a little each time until it finally retracts fully. It goes up smoothly though. My mast is an genuine part too.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
I simply made sure that my antenna mast was all the way down then unplugged the motor. I have a little trouble picking up lower frequency stations, but the higher ones are just fine.
