ST19AG_WGreymon »
https://forums.nicoclub.com/st19ag-wgreymon-u235900.html
Tue Jun 17, 2014 7:43 am
You shouldn't need the Metra harness. But when you receives the PAC ROEM NIS2 here's the way it should hook up:
===Stock audio====I----------------------I
I PAC ROEM NIS2 I===included harness=////==Sony harness====Head unit
You'll just be splicing(////) the Sony harness to the harness that comes with the PAC ROEM NIS2.
The PAC ROEM NIS2 will convert the Nissan audio connections into standard connections, means the colors should all match up as well. Most likely the Bose amp isn't being triggered for some reason, possibly because wire aren't matching up correctly. If the amp isn't triggered the speakers won't work.
