NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Tue Mar 22, 2005 3:38 pm
nah its cake. remove the covers around the steering coloum. then remove the screws holding the instrument outter bezel, should be 2 going upward into the dash in front of the instrument glass, you may also need to remove the knee panel to gain access to the bottom screws of that bezel. then you slide the bezel out and you should see 4 screws around the instrument cluster. remove those and slide the cluster toward you. you can leave it pluggeg in or unplug all the connectors your choice as you should be able to gain access to the bulb with it slid forward. you need to figure out where it is in there. the way to do it is shine a flash light into the front of the cluster and see if you can make out where the "service enine soon" lettering is then go to the back and pull that bulb out so you can replace it.
