New to the forum - 1998 Pathfinder.
Against my better judgment, I used one of those cheap windshield replacement businesses right next to a Pull-A-Part here in Atlanta (mine was cracked and very much illegal). Besides some basic cosmetic nicks from the install, everything seems to be in place. I'm almost certain that they didn't even use a real replacement part but the fit appears to be legitimate and matches almost every picture I can find online with the exception of a couple. I didn't take a close look at mine before they started working...
Anything that I can look for in particular that will make things obvious? It hasn't rained so no idea if it leaks or not.
Thanks
In this picture, the sides of the front windshield are flush against the frame. I'm almost certain that this is how mine did look. Unfortunately, I don't have a single picture of the Pathfinder before I had the work done to compare images.
There is a visible and increasing distance between the frame and the windshield as you move from the roof towards the hood. This is how my windshield looks now.
I could be crazy, but I rarely use cheap businesses and second guess myself every time I do.
