1998 altima won't shift into 2nd, 4th, or reverse?
General discussion area for the L30-chassis Altima
doughboysmb
Car: 1990 nissan hardbody, 1989 nissan hardbody
Got a friend who's car just started the problem, runs fine in 1st, 3rd, and 5th gears but will not shift into 2nd, 4th, or reverse.... has anyone ever run into this problem before? Also its a 5 speed manual to save on any confusion...
lobo_s10
Car: 1998 Altima GXE 5spd, cold air intake, strut tower brace, fireball 2 muffler, vortex generators on roof
Mine 98 altima was doing the same thing replaced motor mounts got slightly better. Then pulled trans out and apart the input shaft berrings were shot and ground out a few gears. Sounds like you may need a rebuild.
Return to “2nd Generation Altima Sedan (1998-2001)”
