1998 Altima Gauge Cluster Bulb Illumination
General discussion area for the L30-chassis Altima
zgendron
Car: 02 Maxima SE 6spd - 09 Nissan Versa SL CVT
Hi All,
I have a 1998 Altima with the Gauge Cluster bulb burnt out. All of the other illumination points are fine: Cig lighter, HVAC, Doors, etc.
I'm guessing this isn't a quick fix, but hoping someone can help me out. I looked in the FSM and didn't really see anything helpful there.
Any help would be greatly appreciated.
Thanks in Advance! - Zack
coldelectric
Car: 1999 Altima SE
Unless you have some electrical issue, you should be able to just replace the bulb. They're type 194 bulbs.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Did you replace the radio at some point? The reason I ask is the radio is part of the illumination circuit. Aftermarket radio installers tend to disregard the orange wire for dimmer control thus damaging the circuit. What happens if you spin the dimmer knob?
Return to “2nd Generation Altima Sedan (1998-2001)”
