s14280zx »
https://forums.nicoclub.com/s14280zx-u40679.html
Fri Aug 14, 2015 8:52 am
Update: After pulling my transmission back out, I found that all of the fw bolts except oue were loosened back up, & one was broken, and the clutch disc was scraping on the bolt heads. I reused the old bolts, and found out that they are not supposed to be reused, just like head bolts, when torqued, they stretch, and since this is the 4th clutch, I probably should have changed the bolts, but never thought to. I bought a new exedy for the ka24de, and I'm using my old ka Fidanza, because I'm not sure what parts I need to change to make the na z32 clutch work, like the bearing collar, & my 280 flywheel got pretty chewed up, but I can still use the new friction surface on my 240 flywheel, so I'm just putting the stock setup back in , & next time the clutch goes out, it's going to be time for an engine swap anyway.
