1998 240sx throttle body hose?
Blackassassin0
Car: 1998 240sx se
Hey guys i can really use some help..I recently attempted to do my first 240sx engine swap it was frustrating at first but then things got easier as i began to make progress..the motor was very very high in mileage and the head gasket blew.. it was time for a new one. I purchased a 1992 240sx motor as a replacement and swapped everything i could from my 98 to my 92 motor.
Heres where things went sour..On my way taking my car out i broke my bvt valve and my map/baro switch solenoid valve.(I forgot to disconnect it before i pulled the motor)
today my buddy broke my engine coolant temperature sesnor too..
But anyways..
I had a question and i was hoping someone could help..its driving me crazy...Where does the hose underneath the throttle body go?I have the factor service manual but it isnt very detailed as far as where the hose has to go..From what ive seen in the fsm..the hose seems to goe somewhere underneath the manifold somewhere i guess..but i dont see a spot to connect it too..i took the manifold apart 3 times already..and im stumped guys..can someone help?? Id appreciate it so much thanks Guys :gotme
corn322
Car: 1993 240sx
Talkin' about this guy?
Also, I don't know how you managed to break a MAP/baro solenoid on your engine, as the 240SX doesn't use a MAP sensor. The two vac switches on the back of the head are the EGR/canister valve and the SCV control valve.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Isn;t that for the charcole canister?
Blackassassin0
Car: 1998 240sx se
Hmm?? So the hose connects to the Tps?
corn322
Car: 1993 240sx
What? Your talking about the hose that connects here, right? (RED AREA)
I don't see all the tubes that run under the plenum (YELLOW AREA) in your pic. Are they missing or can I just not see them?
Blackassassin0
Car: 1998 240sx se
hey guys sorry it took me so long to respond..but yeah..to be honest im not sure..where it goes exactly..does anybody have any pictures of where it could go i cant figure out...on the factory service diagram
biggie
All of those under there (except the IACV hose) are emissions related. So if you don't have emissions on the car then there won't be anything to connect them to.
Blackassassin0
Car: 1998 240sx se
.I do have Emission right now..that's the thing tho=\ this is my first time doing this swap..and it's just that one mystery hose that I cant figure out.....do you have any idea where it goes bro??
Blackassassin0
Car: 1998 240sx se
Rt @ corn322 ima check and see and let you know
alms24sebring
'04 Nissan Sentra SER SpecV
If you still have emissions the first diagram should be right
Blackassassin0
Car: 1998 240sx se
Just so nobody is confused I'm not using a s13 manifold I'm using the s14 98 one!
