96_S14_SE »
https://forums.nicoclub.com/96-s14-se-u2649.html
Sun Feb 16, 2003 11:33 am
You looked up under the rear deck right? Between the trunk lid tension bars and the pass through wall.
Where the wires going to the rear speakers factory (18 gauge wire or so like everything else wired in the car) or an actual speaker wire? That would be the first clue.....
They might have wired the oem harness up to the speakers as well though.
You said the speakers were the OEM clarions right....
I would check how the head unit is wired from the back, and take note of the wiring, as well as double checking the connections and such. Check it against the FSM diagram to see exactly which were used. It could also be that the wire is rather thin and would work fine to send signal to the factory amps, yet is lacking to provide the power from the head unit to the speakers....
Im kinda of curious as to what the front stage consists of.... Did the car come with the 6 speaker setup (rears, doors and a pillar tweets).... Ill double check on the locations for the 98 but I dont see why it would change over the 96 se, only mabey if it came with the 4 speaker setup instead. Im meeting up with my technition friend at his nissan dealership tommorow (wiring up a complete msd ignition for his TT z32 in a very limited time frame hehe) and could pull a FSM to double check.
