NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sun Nov 06, 2005 4:32 am
In your fuse box located in the car check the 8th fuse down on the left side of the box. With the key on check for power with a test light or volt meter on both sides of the back of the fuse. You will prope it in the slots where it has the metal tabs on the fuse.
