1998 200sx sr20det wierd problem!?!?!!??!!
Harvey s13
Car: 1990 240sx hatch
i have a 1998 200sx with a sr20det. for some reason the oil shoots out the dip stip. anyone know why, or how to stop it. it only really happens when you get on it
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Is it coming out the top where the dip stick tube connects to the block or the top of the dip stick tube where you grab the dip stick?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Bad rings? Do a compression/leak down test and see what you get for numbers.
Harvey s13
its coming out the top where you grap the dip dtick to check the oil
Harvey s13
a
the converted wrote:Bad rings? Do a compression/leak down test and see what you get for numbers.
alright man, i'll try that too
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
blow by, do a leak down test on all cyls
big monkey racing
Car: 1990 240sx
Harvey s13 wrote:i have a 1998 200sx with a sr20det. for some reason the oil shoots out the dip stip. anyone know why, or how to stop it. it only really happens when you get on it
i had a similar problem on an eclipse i had turned out to be clogged oil passages. just my 2 cents
Harvey s13
bad news... after i put oil back in it and started it up theres a knocking sound and major power loss. and it keeps wanting to die
s13-t
Car: s13 pig nose w/blacktop sr20det
my sr did something similar. bad pcv valve caused extreme pressures and temps in my bottom end wich in turn gunked up my turbo lines and killed my oil pump. still saving money for a rebuild. Hope your problem is a less complicated one than mine was.
Harvey s13
yeah i'm pretty sure i'm gonna have to rebuild mine too.
