nametakennow »
https://forums.nicoclub.com/nametakennow-u713.html
Fri Feb 22, 2008 12:41 pm
No point in a modified chip or piggyback computer right now.
By the way, the Proformance "chip" (i.e. intake temp resistor mod) is total BS. It'll just make your car run rich and lose power. The only chips out there for your car are JWT's retuned OEM ECU and the Calum custom daughterboard setup, which I'm not even sure he's still doing. Google that "Calum daughterboard" for more info, though you only need any of these if you do some serious mods. Even with cams, you don't stand to gain much more than 5-10hp with a retuned ECU.
I'm not certain what "somewhere in the middle" means, but basically (and I mean VERY basically) here are your options:
Bolt ons - I/H/E = ~$1000 if you do all brand name stuff, closer to 5-600 if you are willing to do some hunting and/or piece together some bits.
Bolt ons + pulleys + cams will net you a good bit more horsepower for an extra $800-1200 or so installed, depending on how expensive your shop is or if you can do it yourself.
Low budget, but quality, turbo setups can be done for $1500 or so if you do bargain hunting and DIY the install. This will net you the most power per dollar, but given that there's bargain hunting involved, it's possible you'll get ripped off.
These figures aren't exact. They're guesstimates based on my own and observed experiences buying and selling parts.
