Heeter »
https://forums.nicoclub.com/heeter-u173796.html
Fri Feb 11, 2011 9:54 am
Hi all,
I dropped off my 98 maxima at a shop this morning for an engine/transmission swap. They are going to put in an engine/transmission combo out of a 2001 maxima. They told me last week that it was going to be a straight swap. Now this morning, another mechanic said that the swap cannot be completed, because the engines are different.
Is there anything I should be aware of for this swap (as in compatibility between the 2 model years)? Should the computer be swapped out too?
I was going to purchase a water pump, and belts for the newer motor so that it can be done while it out, is there anything else I can do to the newer motor before it goes in?
The 2001 engine transmission has 120,000Kms (75,000miles) on the odometer. Saw it myself before they pulled that motor out of it. The 1998 has 200,000Kms (122,000Miles) on it now.
Thanks
Heeter
