causin_ruckus »
https://forums.nicoclub.com/causin-ruckus-u39434.html
Sun Apr 16, 2006 8:01 pm
When my s14 is at idle, after a few seconds you feel it shaking a little bit and then it starts shaking a little harder and then goes back to not shaking and repeat. When i pop the hood, you can see the motor moving about 1-2 inches left and right and then it stops moving. Also, the shifter starts moving too and when you're going fast it starts moving a lot. I checked the mounts and that's not the problem. What can i do/check? Thanks
Modified by causin_ruckus at 1:18 PM 4/17/2006
