Issac »
https://forums.nicoclub.com/issac-u89863.html
Tue Mar 04, 2008 7:16 pm
I don't know if this is related to you, but I was all stoaked on Lucas until....It blew my power steering hose off one car for the powersteering (no big the clamp was loose and the think fluid probably made it kick off). The power steering made a groaning noise after I added it to my other car.
And I did the same service as you on the transmission, and the Lucas, and it make my transmission sluggish and would bump at like 55 uphill in 3rd every once and a while.
I added it to Mobil 1 prior, and was pissed. Because replaced 4 qts of new. So my other car will get the week old 4qts because it liked it cheap (American)
The diluted Lucas didn't do the bump. So I don't know. I want to use the Lucas but it did change things a tad. I have seen some not so good things about the additive for oil also. But I have buddies that did some amazing stuff with it. Long story.
Clogged filters and gunk can do this, but it sure sounds like it is not you case. I have used Seafoam and got junk out that fluid exchange didn't.
also there are BG products that will really clean that up, if that is the problem. I don't know.
Also maybe check your fan clutch. It could be going bad, cooling too much. These can be repaired which is a little secret that they don't tell you.
