Think about the code and what it said! Why did you replace MAF when the MAP assembly is at fault. MAP sensor measure plenum pressure against the earth's supercharger [14.7 psi] as a reference.
Idle 20" HG is ~= [20/29.92=] 9.8 psi in plenum as the throttle is opened the pressure rises progressively to maybe 13.8 psi at WOT 4,000 rpm.
FSM fully describes.
A triple check on the TPS, IAT, and MAF signals. All things nust track with rpm to create the load signal.
"The MAP sensor is then used for rationality checks and to test the EGR valve. The way they do this is during a deceleration of the vehicle when there is a high vacuum present in the intake manifold. During this high vacuum the PCM will open the EGR valve and then monitor the MAP sensor values. If the EGR is functioning properly, the vacuum in the manifold will drop as exhaust gases enter." from
http://en.wikipedia.org/wiki/MAP_sensor
http://autorepair.about.com/li...b.htmh ... so...1mp/1
