rjorgens »
https://forums.nicoclub.com/rjorgens-u206225.html
Sat Dec 29, 2012 2:46 pm
Hi,
I'm a proud 1997 Infinity QX4 owner, it's been a great car and has 186K miles. I only found one other thread with a problem just like mine, and it didn't have a solution, so I'm putting this out there hoping someone knows where to start.
My wife asked me to come and look at the car, because it was running rough. I discovered a mouse nest on the intake manifold, and the little buggers had chewed through a couple spark plug wires AND a couple injector wires. I repaired them as well as I could, car was running fine again (this happened once before so I had a spare set of spark plug wires). Then my wife got stranded 50 miles away, car wouldn't start. It wouldn't even turn over. So I drove up there, wiggled my wire repair, and it started. Started 3-4 times after that just fine. We got it home, and the next day it wouldn't start. Manged to get it to start once by pushing in the brake, taking it out of gear, and putting it back into park. Then it starting working again, so I headed for the mechanic. Started up twice, but ended up having to have it towed to the mechanic. He repaired (better than I did) the injector wires, put a new set of plug wires in, and replaced the positive and negative battery cables. Car ran great for 3 days - now it won't start again.
Symptoms - starter does not seem to engage at all. Battery is full at 12.8V. All the lights on the dash light up, I hear what I think is the fuel pump start up, then absolute silence when I turn the key - headlights don't dim when I try to engage the starter. Because of that I'm thinking maybe it's a transmission lockout switch gone bad, or a security relay somewhere messing with me.
Any help is appreciated. Thanks!
