I hoping some of you can help me out with some issues I'm having.
First. I bought the qx4 without being able to drive her, "bad stater.. turned out just a lose battery connection" thankfully the the owner was honest about the vehicle and told me everything she needs and some more.
The main problem I having is with the brakes. When I push the pedal it travels to the floor before it starts to bite, If I pump them 2-3 times it brakes great and hard.
Today I replaced the Master cylinder "former owner said that's what is needed" and bleed the brakes, although I didn't know of the lsv valve? I bleed the front and back and seen no air "fluid flowed good"
Went for a test drive... and nothing changed.. out $240 for the master... as I can not return the part..
I pulled the hose to the booster and checked the the line, vacuum air sucked hard.
Im out of ideas on whats causing the brake pedal to act this way?
Really thinking the abs pump? The abs light is on. I pulled the two small relays.. but No change..
any ideas? thx
