Wilky »
https://forums.nicoclub.com/wilky-u63676.html
Sat Mar 07, 2009 9:42 am
I have a 1997 q45t with 188,000 miles. About 30 days ago, I was driving to work and the going up a hill and the check engine light came on and the motor really bogged down and felt like it was missing going up the hill. So I decided to get some bg44k fuel injector treatment and run it through the tank and the problem cleared up and the car started to run much better. The codes at that time were the two knock sensor codes with circuit failure. So I reset the codes and about a month later it happens again only this time, it has the two knock sensor codes, with a misfire on cylinder 2. Where should I start, Could a coil pack be bad on cylinder2 and cause the knock sensors to trip. Please give me some direction. I bought the car with 110,000 miles. It had always had dealership service in Austin, Tx. Since, I have owned it, I have had all of the fluids changed. Then spark plugs, oxygen sensors, valve cover gaskets, Belts, etc. plus all of the routine oil changes, air filters, fuel filter, etc. I have not done anything beyond that.
THanks
Dan
Modified by Wilky at 1:37 PM 3/7/2009
Modified by Wilky at 1:38 PM 3/7/2009
