oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Sat Sep 12, 2009 5:35 am
Could be your blinker fluid, or most anything else. Hard to say.
If it were mine, first thing I'd do is run some quality fuel system cleaner through it along with a tank full of fresh, quality gas. Replace your fuel filter if it's less than a year old. Todays E fuels pretty much suck. Might not be a bad idea to add some ISO heet as well.
Lots of discussion here regarding fuel additives. BG44k used to be the sooper-jizz, but a recent change to it's formulation has caused much angst, consternation and trepidation among the Qmasses. Seems to me that "Redline" is the new jizz-du-jour but from my comfy chair I have no idea.
Shoot some MAF cleaner on your MAF.
There are some here who will tell you that it's time to douche the entire intake and all the associated plumbing and bits. To spend a grand on new hoses, gaskets. To take your car out of commission for two days to get it all done. To lay bare the top of the engine and find every little piece of crud and carbon and sanitize. He's currently on sabbatical.
That's a lot of work, with no guarantees of a fix and opens you up to large exposure to other problems. Try the easy stuff first.
Bad gas is almost as bad as bad juju. Best of luck in the rectification or your rides anomaly.
