smoke9 wrote:....... At the same time the car will idle irregulary. It will idle down as if it wants to cut-off, then idle back up. when i put it in the drive position and take off from 0-30 mph it seems as if it wants to stall.
Sounds an awful lot like the Mass Air Flow (MAF) sensor to me. CEL on? Have you pulled the codes? An easy thing to check is the MAF connector. The one in the pic may look different than yours but the idea's the same. The connector and the MAF pins should be free of corrosion and the connector pins should fit tight. When lubed with dielectric grease and tightened properly it shouldn't wiggle up and down more than 1/8". Is the connector's metal clip still in place? A lot of (new) owners start having connector problems after a Jiffy Lube oil change where the lube tech has forced your air filter out of the airbox with the MAF connector attached to the MAF/airbox lid. Tighten up the pins with a pointed tool (small nail).
smoke9 wrote:.........when i put it in the drive position and take off from 0-30 mph it seems as if it wants to stall. When it feels like it wants to cut off the car begins to jerk. im not sure what the problem is.....
Wes is busy with school but if he were here tonight he would say check your fuel pressure. It's probably the fuel pump or fuel pump control unit (FPCU) gone bad. Have you replaced either? How many miles on your Q? Sound like a swarm of bees in your trunk?
Do the easy stuff first (clean up MAF connection) and see if there's any improvement. Get back to us with some maintenance history. Good luck.
