Don't mean to butt heads, but you don't NEED to remove the upper plenum. You just have a little less room to play with. I did not pull mine off when I did it the first time.3Q Jay wrote:vcg on fgy33 is cake compared to g50 and of course i have done both.
do pass side first to give yourself confidence.
you won't get the driver's side off unless you remove the upper plenum or cheap out and cut a bracket off.
of course, i recco to remove the upper plenum (have the upper to lower gasket on hand and some vacuum hose) so that you can clean it, the tb, and the egr tube real good.
Did you get this problem fixed? The rpm problem I'm speaking of.NickY33 wrote:greeeaat. so got the car back, and the TCS and SLIP light are off, and supposedly everythings good to go, BUT when im at stop lights, the car idles at about 500 rpms and shudders, the rpm gauge moves very slightly, goddamit problem after problem!
would this work for a 99 Q? i called several local shops around my area & i've been hearing different things. They told me they would have to also pull off the upper intake or the plenum or the throttle body. Do any of these things need to come off for the job to get done? someone lmk asap! bringing my car in next week to get this done & don't wanna over pay.S13xCrazy wrote:There are times that I feel like I am one of the only guys that get down and dirty on VH41's
Don't be scared to do it, it's a piece of cake. I think it took me an hour to do it total.
1) Remove main engine cover - 4 10MM bolts
2) Remove passenger side engine cover - 4 10mm bolts
3) Remove coilpack plugs
4) remove the 8mm bolts holding them on
5) Pull coilpacks out
6) Unbolt all of the 10mm bolts holding it on
7) Pull off any hoses going to the valvecover (my car is covered in snow right now or I would go check it out)
8) Remove valve cover
9) Put new gaskets in, use a little ultra black gasket maker where needed
10) Put together.
The only hard part is getting the gasket to stay in the valvecover while you put it on. I always use a little ultra black on the valvecover side to make it stick
The VH41 is a super simple to work on - They gave us TONS of room in the bay!
