1997 Q45 Transmission filters...
5zigen
Whats a good brand to use? Thanks in advance...
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
you mean other than oem?
1 888-216-5328
filter is 27.58,o-ring on filter is 1.09gasket with onetime bolts is 20.34
forget about 20 years ago whn you bought your th350 kit at pepboys for 9.99.
don't forget to clean the goop off the magnets in the bottom of the pan [they come out] while you are in there.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
GQ Jay wrote:Don't forget to clean the goop off the magnets in the bottom of the pan [they come out] while you are in there.
Don't forget to wipe the inside of the pan also. Do get a mechanical exchange so you start with new fluid, and add the cooler while you are at it.
FarFetched
Car: Suzuki SV1000S.
I used NAPA GOLD trans kit (30$) comes with everything. I compared NAPA with OEM. There is no significant difference. Fit is right and dimentions are the same as OEM. It is just a wire-mesh screen it doesn't filter fluid as good as "glass enhanced" media. RULE OF THUMB - COMPARE PARTS BEFORE YOU INSTALL THEM! Cheers!
