kevinis wrote:the time he got a code on cylinder 3, there was no check engine light lit.
That can indeed happen. Reset your ECU, switch coilpacks 1 and 3, then scan in a week or two. If it follows the coilpaci, then it is the culprit. If not, you have some more diagnostice to perform.
No TSB to my knowledge and my speculation is that it never occurs before OEM warranty expires and dealer approach is to repalce all coilpacks as a wear item.
Cannot stress enough the importance of a clean intake path preliminary to diagnosing your problem. Many erroneously assume there is a single cause for any particular symptom when in fact there may be multiple and different causes.
