qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Thu Jul 31, 2008 3:40 am
It is not a "service engine light", it is a malfunction indicator light that only illuminates when the computer detects a FAULT in one of the systems it monitors and controls.
Resetting it without researching the cause and correcting the issue is not the way to handle the problem unless you are in denial.
Have the codes read at a service provider and attend to the subsystems indicated by the specific code to correct the issue.........ony then do you reset the lamp to extinguish it. Autozone and others will read it for......FREE
