1997 Q45 Rotors?
Da Dark Jedi
Car: 1997 Q45
Just purchased a set of Hawks Performance brake pads for the front. Now I'm looking for a better than OEM rotors to put on also. Can you you guys give me an idea on which to buy and where from?. I'm looking for the usual long lasting & better grade steel.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
brembo blanks are a good low cost OEM quality alternative.
Q45tech
What ever you use be sure to TOTALLY COMPLETELY flush brake fluid and replace with Valvoline SynPower Brake Fluid at the minimum [most cost effective for street].
Centric BLACKHAT PREMIUM Cyrogenic Rotors are what we use when customer does not want to pay for oem replacements. Standard non blackhat are very inferior to oem so be careful.
http://www.centricparts.com/index.php/about-us
Make sure the front rotors weigh at least 18.75 pounds!
