1997 Q45 No heat, trouble code -26
fontana dan
Car: 1997 Infiniti Q45
Hello folks,
Yesterday it was a little chilly so i tried to use the heat in my Q for the first time. Surprise, no heat whatsoever. AC blasts out the vents with temp set at 85F on hvac control. Self diagnosis returns code -26 "Air Mix Door Motor PBR."
First off what does PBR mean?
I've located the component and pinpoint test in the FSM for '97 but unable to find full electrical schematics or connector view for HVAC system.
Any advice on this before I tear into the dash? I see the motor is supplied 5v from a module called "HVAC Amp." What is that?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
PBR = Precision Balance Resistor
The mix door actuator is basically a garden variety servomotor with a built-in feedback potentiometer (pot) that tells it what position the mix door is in. The problem could be an open in the wiring, but most likely it's just a bad pot and you need to replace the actuator.
fontana dan
Thank you for the input VStar.
I found the full electrical schematic and was able to test the circuit with a multimeter. Key on engine off. Unplugged air mix door actuator connector M43. Probed connector M43 pin #3 found steady 5v.
+/- 10V on pins 4 & 5 on connector M43 depending if climate control is set at 85F or 65F. Seems like the circuit is functioning from the auto amp.
Testing the actuator component itself I get 200ohms across pins 3 and 1 for the PBR with door stuck at full cold. Was not able to find any continuity across pins 4 and 5 for the motor...thinking that could be an issue. Ordering a new air mix door actuator p/n 27732-70F00.
VStar650CL
Technical Expert
The motor brushes or nylon gears are always the prime suspects with actuators, whether you're talking about HVAC or headlight aimers or anything else with analog movement control. Since the late '80's they all use "toy boat" sealed brush motors with monster gear reduction, and none of that stuff lasts forever. Chances are your motor brushes are simply gone.
fontana dan
So I removed the old actuator and it started working from being jostled around I guess. Reinstalled and I have heat now.
VStar650CL
Technical Expert
Hope it stays working, but it probably won't. That isn't much different from whacking a balky starter motor, the next time it lands on the same bad brush you get another no-start. That isn't graven in stone, but some finger-crossing will definitely be in order.
fontana dan
Yeah I have no clue how long it will continue to work. Finger-crossing is in order.
Also appears there may be another issue with the car unable to maintain a steady operating temp in cold weather(45F). Will keep a close eye on that.
But for now the cabin is warm. Thanks for the help vstar.
Q451990
fontana dan wrote:
Tue Oct 11, 2022 11:07 am
I would replace the thermostat. The rubber seal around the edge will deteriorate, and let some coolant bypass it when it's supposed to be closed.
fontana dan
That did not last long. New air mix actuator on order from this site after they cancelled the order days ago...
https://parts.sawgrassinfiniti.com/p/IN ... 70F00.html
fontana dan
Actuator on indefinite backorder from that website. I know some dealers have the part across the country but they want like $300+ for it.
Going to go to the junkyard when I get a chance, to get a spare air mix actuator from a 90s Nissan for some experimentation.
chrisbr66
Car: 1997 Infiniti Q45t
Hi, I'm also replacing the actuator in my car also. Any hints to getting it out? I'm having a hard time getting the top 4 screws out
fontana dan
I'm attaching a picture of the mix actuator. It is directly next to the gas pedal, a black piece with white arm and pink wires on the electrical connector.
In my '97 it is held onto the bracket with 3 8mm hex-head screws. You can use a short 8mm box end wrench, or a low-profile phillips head socket to remove it. To remove the connector you press the tab downward.
In this picture the metal rod on the left is the gas pedal. Air mix actuator is the dusty thing.
I found a '99 Q45 in a junkyard but the part was different on that car. bummer
chrisbr66
Hi Dan, thanks for the info and pics. The one screw towards the back right back was a pain to get to but finally got it. Replaced the actuator and now have heat, just in time for the winter. I will wait on the AC compressor replacement until the spring. Thanks again.
Chris
fontana dan
Hey chris. Where did you buy the replacement actuator? I've been looking around for a used one, but as it gets colder and colder here I'm thinking about coughing up the $$$ for the OEM part from the dealer.
By the way, if anyone has a 97-98 Q45 sitting around with a good air mix actuator and wants to send it to me...I will pay.
chrisbr66
infinitipartsdeal.com I paid 156.00 for mine, got it pretty quickly
fontana dan
Ordered a new actuator online from a local Nissan dealer. About $190 out the door, heat is good now.
