1997 Q45 new alternator
airman
Car: q45t
Just spoke with Infinitiparts, they don't have new alternators, only remanufactured. I read here that everybody suggests to get a new one. Where do you people get them?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
The Nissan remanufactured ones from
http://www.infinitipartsusa.com
is what you should get.
airman
Car: q45t
Got it. Thank you!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
BTW, check the TSB as i think there was a recall on the 1997 alternators. If the car is out of warranty, as it most certainly is, the car is now probably not covered.
Q45tech
About time for recalled replacement units to start failing..........top mounted as they are.
Q451990
Q45tech wrote:....top mounted as they are.
Interesting comment. Does top mounting reduce the life of the alternator due to more heat?
Heath
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes. The VH45DE mounting is cooler as it is under the block.
