oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Thu Dec 02, 2010 6:51 pm
I'll toss in my opinion but I have NOT read the other responders, so if I say something twice or duped advice just blow me off and chalk it up to Modelo Negro, and Two Buck Chuck Cabernet.
Do you have any wrenching skills?? I only "axe" because you take it to the dealer for oil changes. If you don't wrench for sport and self abuse, then ignore most of my post. If you wrench, well.....here goes...
Most of this is EASY stuff.
1. Order some belts from IOS, along with the cabin air filters. While you wait for them to show, download the Facroty Seviovioche Manwell. FSM. Read up on the belts, the tensioners, and the filter(s) install.
2. Drive hot rod to Advance Automobilio. While there, purchase any tools you may need, and two cans of fuel jizz.....I like the chevron stuff...techroline or whatever its called. Its expensive and worth it.
Buy two quarts of brake fluid. Make sure you get the correct one. (FSM)
Buy a three dollar brake fluid changer gizmo, unless you have a nubile and willing assistant.
Buy a candy bar or three. Maybe a cheap flashlight and a creeper too. Beer is good.
Buy some good engine oil (synthetic and a good filter)
Buy some synthetic rear end diff fluid. M1.
Buy some new wiper blades...they're probably shot, or will be soon.
Buy one of those cool little wire gizmos to clean your batt terminals. Everybody needs one.
Buy a new fuel filter, and an air filter. Once a year for these mofos.....probably time or soon.
On the way home, add the fuel stuff to the tank and fill it up. Do this again on the next fill up.
Jack up front end of hotrod and replace belts. Not hard, but particular....like a jig saw puzzle, only you'll probably have to go inside to pee, and its a lot dirtier. The tension is very important, but its not rocket science. Took me two hours or so, and saved me almost three hundred U.S. Dollars. That's a lot of bourbon.
Change oil while under the beeotch and dirty. Ditto the fuel filter. You read the FSM right?
Bleed brakes with the little gizmo, or have your nubile assistant help. The goal here is to shoot fluid out till it comes out clean. Make sure that you keep the fluid level up in the reservoir! Shoot some Aerokroil or PB blaster on the bleeder first.
Really, this ain't that hard.
After you get nice clean fluid from all the bleeders...have changed the engine oil....the fuel filter.....used tie wraps to rehang all those cheezy little plastic gizmos which supposedly hold the wires and fuel lines and stuff...shot some aerosol undercoat on the rusty stuff...took a gander at the goings on.....etc...
Grab a 10mm socket, a mess of extensions, a ratchet handle and your pick of adapters.
Slowly and gently, go around and tighten all of the valve cover bolts. Yes, this is considered heresy. Just go slow, be deliberate and tighten all the damn bolts. Use your head and only give each one a tiny twist before moving on to another. Don't just wail on em, and don't do them in line...move around so as not to ruin the cover. You're wrenching on aluminum...not iron or unobtanium, so don't get all Cro Mag. Tighter, but not so damn tight that you ruin the threads.
If you are lucky (as I was), this will stanch the flow of oil and your problem is gone. Of course this may NOT work, but it did for me. I did this three years and 80,000 miles ago as opposed to the huge and heinous job of total gasket replacement. My leaks are gone.
Your results may not be as good as mine, but this technique is FREE and if it fails, tear into it another day or pay someone to do it. Shoot some aerosol engine degreaser all over the drips and rinse with a hose when done. This will help you determine if your efforts were fruitful.
Clean the batt terminals while you have the hood up and are dirty. Close hood and replace wiper blades. Crack another beer.
Call around and find a shop which uses the BG transmission flush machine. Have them run the machine on your car. They will use synthetic trans fluid during the job. Not too shabby. Have them change the rear end fluid at the same time. You brought them two qts of M1 right?? This job is too messy, and the car cannot be jacked up enough at home. Let them earn a buck.
Find another good shop and have them rehab your front end. Shocks, mounts, bushings, tension rods.....the works. Pricey as hell, but you saved about a grand by doing all the other crap yourself and your car will amaze you when you this work is done.
